Jul 16th, 2024, 8:28pm
ncelab unable to find a unit named 'mixedsignal_2' (Read 13263 times)
Dec 25th, 2008, 1:24am
Hi guys,
I failed to simulate a PLL model using ncsim. The model is dg-vamsA-10, which is taken from "The Designer's Guide to Verilog-AMS" by Kundert & Zinke.
http://www.designers-guide.org/Books/dg-vams/chA/chA-listing10.tgz
The error information is shown below.
ncelab: *E,NOUNIT: Unable to find a unit named 'mixedsignal_2' in the libraries.
ncsim: 05.60-s006: (c) Copyright 1995-2006 Cadence Design Systems, Inc.
ncsim: *F, NOSNAP: snapshot 'plltop' does not exist in the libraries.
The nc version is IUS56. What is mixedsignal_2? Where is it defined? Thank you in advance.
Yawei
Re: ncelab unable to find a unit named 'mixedsignal_2'
Reply #1 - Jan 5th, 2009, 5:58am
mixedsignal_2 will be the connectrules. It doesn't appear to be in the tar file - I had a quick scan around and couldn't find it elsewhere, but that's because it's using the mixedsignal_2 connectrules compiled into the connectLib that comes with IUS.
You should find the code in:
<IUSinstDir>/tools/affirma_ams/etc/connect_lib/crules2.v
If your IUS installation had the "configuration" step done after installation (which you really should do), and you have $AMSHOME pointing at your IUS installation root, the connectLib library should be found - it should be in the connect_lib directory. In the example, the cds.lib looks like this:
include $AMSHOME/tools/inca/files/cds.lib
define worklib ./worklib
Using my configured installation, I was able to run "run-me" without doing anything else (I have $AMSHOME set too).
Reply #2 - Jan 6th, 2009, 1:57am
Andrew, thank you.
The configuration step was not performed after the installation. I have found that directory and compiled the library named connectLib. It's done.
