Aug 15th, 2024, 1:38am
Modelling of frequency-dependent resistor (ferrit choke) (Read 5119 times)
Berti
Jan 05th, 2009, 11:43pm
I need to model a frequency-dependent resistor (phase should be relatively constant) - basically a ferrit choke. How can I do that in spectre/veriloga? A combination of R-L-C elements doesn't work since this doesn't result in a constant phase?
Any ideas?
ACWWong
Oxford, UK
Re: Modelling of frequency-dependent resistor (ferrit choke)
Reply #1 - Jan 6th, 2009, 12:55am
Maybe this piece on skin effect (resistance varying with sqrt(freq) in this case) will help ?
http://www.designers-guide.org/Modeling/ind.pdf
Berti
Reply #2 - Jan 6th, 2009, 6:49am
Cool, thanks a lot! That's what I was looking for.
Cheers
