Jul 16th, 2024, 10:16pm
How to dump to fsdb in ultrasim (Read 4753 times)
Rooney
Jan 07th, 2009, 3:18am
Can any one please tell me how to dump the output in fsdb format while using Ultrasim. I am running Ultrasim in ADE-GUI mode.
It supports only SST2 and PSF format (in ADE environment, simulation -->option-->analog-->output). It doesn't have any fsdb format.
yongjie
Re: How to dump to fsdb in ultrasim
Reply #1 - Jan 7th, 2009, 8:33am
You can generate the list file and find the following script in the list file:
*ultrasim: .usim_opt  wf_format=PSF
modify the script to:
*ultrasim: .usim_opt  wf_format=FSDB
save the modified list file and run Ultrasim in command line
View Profile yongjie yongjie   IP Logged
Dipankar
Reply #2 - Jan 8th, 2009, 4:48am
Rooney wrote on Jan 7th, 2009, 3:18am:
Dear Rooney,
                  Add this following line to your .cdsinit .
envSetVal("UltraSim.opts" "useOtherOutputFormat" 'boolean   t)
and invoke icfb.
You will find FSDB option in ADE -> simulation -> option -> analog -> output.
With Thanks and Regards,
Dipankar.
