Don't use unfamiliar abbreviations such as "U R right", "Do U", "LA".
And use industrial standard words which everyone can understand.
taotaohai wrote on Jan 10th, 2009, 10:10pm:"the tape-test process" is means that,in the process of testing of the chip.
I don't think "the tape-test process" is a standard term which everyone can understand.
taotaohai wrote on Jan 10th, 2009, 10:10pm:Just as you said,my spectrum analyzer is Agilent PSA or ESA Series Spectrum Analyzer.
There is big difference between PSA Spectrum Analyzer and ESA Spectrum Analyzer.
taotaohai wrote on Jan 10th, 2009, 10:10pm:I used detector mode of "sample" and RBW=3MHz.my spectrum is Center=13.26GHz and Span=26.49GHz.
You should use "positive peak" detector mode.
taotaohai wrote on Jan 10th, 2009, 10:10pm:"an average of all frequencies on the map after." ,in frequency domain,in any point,the spectrum is not stable.
So I get the average of every point ,which seems relatively stable just shows in the chart.
Your spurious peaks in spectrum vary with time ?
Frequencies of spurious peaks are constant ?
Amplitudes of spurious peaks are constant ?
taotaohai wrote on Jan 10th, 2009, 10:10pm:I guess the two reasons.
There is no description about reason in the following sentences. You refer first your post ?
taotaohai wrote on Jan 10th, 2009, 10:10pm:For my circuit,there are 12 stages,8 loops.
the total gain is 49dB,every stage is about 4--5dB.
Before tape-out,simulation shows that the cutoff frequency(you mean the GBW?) of the LA is about 36GHz,and -3dB BW is 17.5GHz.
I mean cutoff frequency, fc as -3dB BW.
If I mean GBW, I refer it as transition frequency, fT.
In your simulation, how do you check stability of cascaded amplifier having multiple feedbacks ?
taotaohai wrote on Jan 10th, 2009, 10:10pm:"With no input signal, none of amplifiers is saturated ?"
Do U mean the input noise makes the amp saturated?may be.
Yes. But your total gain of limiting amplifier is not so large, so none of amplifiers could be saturated with no input signal.
taotaohai wrote on Jan 10th, 2009, 10:10pm:The purpose of my feedback is two facets:one of the loops is for canceling offset,the others are for broaden BW.
Very common.
taotaohai wrote on Jan 10th, 2009, 10:10pm:Please help me expert analysis of this spectrum:that's may be a mistake.I just want someone who understands could help me find the reasons for this spectrum.
Specrum you attached is fairly old, almost one year has passed after you measured spectrum.
Why have you left your problem unresolved ?
Try to vary power supply voltage and observe behavior of spurious peaks in spectrum if power supply of your amplifier is not regulated by on-chip regulator.
If you re-observe spectrum more preciously with peak detector mode, is there any periodicity in spectrum ?
