Jul 28th, 2024, 11:35am
PSS and Pnoise simulation for auto-zeroed SC integrator in Sigma-delta (Read 8716 times)
happyday
Jan 13th, 2009, 4:46am
Dear all,
    I have a question about using PSS and Pnosie to simulate an auto-zeroed SC integrator in sigma-delta modulator.
I want to know the 1/f noise corner of an auto-zeroed SC integrator
I have tried three different ways.
All simulations are done with zero input and 5V clock signal.
1) SC integrator (with Cs and Cint), normal connection:
Choosing noise type to "time domain", I can only plot output noise. Thus I need to divided it by the transfer function.
Thus I simulated the PAC simulation, however I can not get
the expected transfer function of the SC integrator. I use SC CMFB.
If I change it to CT CMFB. I can get the PAC transfer function I want.
2) SC integrator (with Cs and Cint), close loop by adding an S&H to feedback the output of the integrator to the input during the next integration phase.
This is described in Ken's paper about device noise simulation in Sigma-delta.
Since it's a unity gain feedback, the output noise will equal to the input noise.
PAC transfer function = 1 at low frequency
3) SC integrator (with Cs and Cint), normal connection, and then followed by a S&H, not close loop. This technique is described in Ken's paper about SC-filter. I only sample the point at the end of the integratotion phase.
For these three techniques, I got different 1/f noise corner, I am not sure which one is the correct way to simulate
the input inferred noise for auto-zeroed SC integrator.
Is there anyone who knows about this problem?
Thank you very much in advance and I appreciate it.
happyday
Re: PSS and Pnoise simulation for auto-zeroed SC integrator in Sigma-delta
Reply #1 - Jan 19th, 2009, 4:30am
Sorry that I did not explain the things clear.
Here I upload some pdf files that explain the problem.
the UGB of 1st opamp is 7 time the sampling frequency fs.
fs = 40kHz.
sampling capacitor cin = 3pF, integration capacitor cint = 12pF
the integrator is using CDS (correlated double sampling) to reduce
1/f noise.
SC_integrator.pdf   shows the topology of the integrator
noise_plot_not_close loop.pdf  shows the "time domain" pnoise result
of topology "SC_integrator.pdf"
SC_integrator_closeloop_SH.pdf    shows the close loop of the integrator by a sample & hold.
noise_plot_closeloopSH.pdf shows the "time domain" pnoise result
of topology "SC_integrator_closeloop_SH.pdf"
happyday
Reply #2 - Jan 19th, 2009, 4:31am
pnoise plot of SC_integrator
happyday
Reply #3 - Jan 19th, 2009, 4:32am
SC integrator close loop topology with sample & hold
happyday
Reply #4 - Jan 19th, 2009, 4:33am
pnoise plot of SC integrator (close loop) with Sample & hold
happyday
Reply #5 - Jan 19th, 2009, 4:39am
My questions are :
1/f noise corner is difficult in these two cases.
How can I get a transfer function of the SC integrator? I can not get an expected transfer function of SC integrator
(with opamp's DC gain at low frequency).
Hope I make it clear now.
Thank you in advance!
ShaXia
Delft, the Netherlands
Reply #6 - Feb 8th, 2011, 1:20am
I am also simulating the auto-zeroed SC integrator, and I have come up with similar results.
To my greatest surprise is that the noise floor of open-loop simulation and closed-loop simulation are different. I also saw that in your simulation result: about 250 nV/sqrt(Hz) for the open loop simulation and about 600 nV/sqrt(Hz) for the closed loop simulation.
For me, the noise floor of the two simulations are also different: 80 nV/sqrt(Hz) for open-loop and 275 nV/sqrt(Hz) for closed-loop. I am using 10 pF Cs and sampling at 5 Mhz.
I wonder why this is the case.
View Profile ShaXia   IP Logged
ShaXia
Reply #7 - Feb 9th, 2011, 7:52am
Now I get it: in the closed loop simulation I have to use "source" pnoise simulation, so that the calculation is still in frequency domain.
The problem with doing time-domain pnoise simulation with close-loop is that the sampled noise comes back into the integrator input via the feedback path and gets amplified. That is why when I did close-loop time-domain simulation I get a much higher noise floor of the integrator.
