Sep 24th, 2026, 9:17pm
maximum integer in verilog-A/AMS (Read 2207 times)
Aigneryu
Jan 13th, 2009, 8:24am
I thought 32-bit integer can be used in verilog-A; however, it may not be the case. I tried to use an integer variable/parameter in verilog-A model in spectre simulation, but the system told me that only maximum 2097152 is allowed.
Does anyone have this problem before? I need an at least 24bit unsigned integer. I have tried if it is due to the parameter or the integer variable, I used both in my model.
Re: maximum integer in verilog-A/AMS
Reply #1 - Jan 13th, 2009, 9:59am
Really? From my quick experiment, the largest integer is 2147483647 (2^31-1) which is reasonable if it is signed. I tried in both the latest MMSIM70 Hotfix, and IC5141 (so quite an old release of spectre).
Which version of spectre are you using? Can you post the code example that breaks?
It seems a bit odd that the number you gave is 2^21
Aigneryu
Reply #2 - Jan 13th, 2009, 11:49am
My mistake. I just found it was my mistake. I put a upper bound on the parameter hidden somewhere in the long code.
I also confirmed that the integer can go up to 2^31.
Thanks.
neoflash
Mixed-Signal
Designer
Reply #3 - Sep 18th, 2010, 9:35pm
How can we enable a number even larger?
say, 2^128 ?
Aigneryu wrote on Jan 13th, 2009, 11:49am:
Thanks.
Reply #4 - Sep 18th, 2010, 10:03pm
neoflash wrote on Sep 18th, 2010, 9:35pm:
say, 2^128 ?
Treat it by four subblocks with 32bit bus width.
neoflash
Mixed-Signal
Designer
Reply #5 - Sep 18th, 2010, 10:22pm
Good idea.
I just did so for a 64/66 scrambler.
