Jul 17th, 2024, 10:43am
Output of Kv when my rail-rail is 15v (Read 195 times)
kumar.g
Frankfurt, Germany
Sep 17th, 2010, 2:42am
Hallo all,
        I have implemented a thermistor and ofet using verilog-A and designed a simple temperature sensor. I give a Vdd of -15V but the sensor output is in Kilo volts. I have attached the necessary files. Could somebody tell me what is wrong with it? Is it the simulator or the model?
View Profile kumar.g write2rammy   IP Logged
Re:  Output of Kv when my rail-rail is 15v
Reply #1 - Sep 17th, 2010, 7:35am
Kumar,
   Looked through the code and had one question. Have you tested
the thermistor in isolation? If you bias the thermistor from a current
source and sweep temperature does it behave as expected?
Sometimes it is better to be more methodical when developing a
model. Test the thermistor and then test the thermistor with the
OTFT model.
kumar.g
Frankfurt, Germany
Reply #2 - Sep 17th, 2010, 8:54am
I didn't test the thermistor with current bias. But I used a MOSFET instead of OFET and the output was reasonable. So I guess the problem occurs when the two verilog-A models interact.
Reply #3 - Sep 22nd, 2010, 5:45am
Verilog-A is case-sensitive (M=Mega, m=milli), do you really want 2.5e6 Ohms as the resistance?
parameter real res_t0 = 2.5M;
If you have a milliAmp current going through that resistor, you'd get kV.
Reply #4 - Sep 22nd, 2010, 5:49am
I also don't like that transistor model -- firstly, that it's completely off for Vds>=0 (I see you expect Vdd=-15, whereas I expected Vdd>0, but still, during Newton's method, you might get a positive Vds in the model).
Have you done some Id/Vd plots at different Vgs?  It looks like the current is at least continuous (for Vds<0 but approaching zero, the current does properly go to zero to match the 0 for Vds>=0).  But I can't tell by inspection if the conductance (derivative of Id) is well-behaved.
kumar.g
Frankfurt, Germany
Reply #5 - Sep 22nd, 2010, 6:47am
Hello Coram,
        The resistance is 2.5Gohms. But I used 2.5M.. I actually require very small current in the range of nA.. I have simulated the thermistor in matlab. I got decreasing resistance as temperature increases.(30,40,..70). But in cadence, the resistance follows with that of matlab until temperature=50 and then it behaves strange. I tried to strobe the resistance inside verilog-A model and I mean to say the calculated resistance itself is wrong after temperature=50 .
Reply #6 - Sep 24th, 2010, 1:47pm
After 50, eh?  I put in this line:
$debug(" temp=", temperature, " res = ", res);
and found that at about 53, the resistance from your polynomial is negative!
