Really? From my quick experiment, the largest integer is 2147483647 (2^31-1) which is reasonable if it is signed. I tried in both the latest MMSIM70 Hotfix, and IC5141 (so quite an old release of spectre).
Which version of spectre are you using? Can you post the code example that breaks?
It seems a bit odd that the number you gave is 2^21 Regards,
