Jul 17th, 2024, 12:34pm
strobing data to a file using Verilog-A (parameterizing the file) (Read 4006 times)
vivkr
Jan 20th, 2009, 3:48am
Hi All,
I see the forum is for Verilog-AMS but I hope that Verilog-A questions are also relevant here.
I am trying to use a Verilog-A block to strobe out some signals to a file. I would like to be able to define the destination file when I instantiate the Verilog-A strobe block, and not have it hard-coded. How can I do this?
I tried to define the filename as a string parameter
parameter string myoutfile
But this gives me a syntax error. The compiler says that this is not allowed without specifying why. With spectreHDL, this was never an issue, but the simulator I am using does not support it and I need to write the function in Verilog-A.
I would be glad to have any tips.
Vivek
Re: strobing data to a file using Verilog-A (parameterizing the file)
Reply #1 - Jan 20th, 2009, 7:37am
string parameters were added in LRM2.2, and some simulators haven't fully implemented that LRM, never mind that it was approved in 2004 and LRM 2.3 is now available.
Reply #2 - Jan 20th, 2009, 7:48am
With VerilogA in spectre, this is supported - although  you have to miss out the keyword "string":
 parameter data_file = "random_static";
There's a CCR 352942 asking for full support based on the LRM. Please contact Cadence customer support and ask them to file a CCR as a duplicate of this - the more this gets asked for, the higher priority it will get.
vivkr
Reply #3 - Jan 22nd, 2009, 1:05am
Dear Andrew,
Thanks a lot. That solves my problem nicely.
Vivek
