Verilog-AMS
Analysis
Modeling
Design
Theory
Welcome, Guest. Please
Login
or
Register.
Please follow the Forum
guidelines
Aug 15
th
, 2024, 6:22am
Home
Help
Search
Login
Register
PM to admin
Design
RF Design
› how this charge pump works?
Previous topic
Next topic
how this charge pump works? (Read 5787 times)
sapphire
Jan 20
th
, 2009, 12:57pm
This is so called dickinson charge pump. Anyone knows how this circuit works or there is any weblink regarding this? Thanks
IP Logged
Re: how this charge pump works?
Reply #1 -
Jan 20
th
, 2009, 3:53pm
Did you try google? I found several good references, even if you give the name as dickinson instead of Dickson (which is what it should be called). Just searching with "dickinson charge pump" or "dickson charge pump" gives:
http://www.eecg.utoronto.ca/~kphang/ece1371/chargepumps.pdf
http://www.edacafe.com/books/McGraw_Hill/Charge_Pump_Circuit_Design/45xch01.pdf
But there are plenty of others.
IP Logged
Previous topic
Next topic
Forum Jump »
» 10 most recent Posts
» 10 most recent Topics
Design
»» RF Design
- Analog Design
- Mixed-Signal Design
- High-Speed I/O Design
- High-Power Design
- Mixed-Technology Design
Analog Verification
Measurements
- RF Measurements
- Other Measurements
Modeling
- Semiconductor Devices
- Passive Devices
- Behavioral Models
Design Languages
- Verilog-AMS
- VHDL-AMS
Simulators
- Circuit Simulators
- RF Simulators
- AMS Simulators
- Timing Simulators
- System Simulators
- Logic Simulators
Other CAD Tools
- Entry Tools
- Unmet Needs in Analog CAD
General
- Tech Talk
- News
- Comments and Suggestions
- Opportunities
« Home
‹ Board
» Powered by
YaBB 2.2.2
YaBB
Copyright 2002-2024
Designer’s Guide
All rights reserved.
Send comments or questions to
editor@designers-guide.org
. Consider
submitting
a paper or model.
