jbdavid
It might depend on the analyses you need to run. generally one needs to support both small and large signal response.
for functional purposes modeling A = gm*Rout is usually sufficient, and allows the gm to be computed from the basics, like Vcm(im), and Ibias. Your mileage may vary. jbd
