Jul 19th, 2024, 6:18am
Cadence IC5141 editor problems (Read 1297 times)
JanB
Jan 26th, 2009, 7:05am
Hi I am pretty new to Cadence Administration. We have encountered the following problems to which I found no suited solution yet.
Everytime I click right on any view in the Cadence Library Manager the Library Manager crashes with the following error message:
X Error of failed request BadWindow (invalid window parameter)
Major opcode of failed request: 38 (X_QueryPointer)
Resource id in failed request: 0x25
Serial number of failed request: 83739
Current serial number in output stream: 83739
It is posible to open any view by double clicking onto it but then it opens in read-only mode (not a big problem cause you can make it editable by clicking on Design - Make editable or press control + O). But now we want to use Verilog-A views and if you open them by doubleclicking they are read-only and there is no way to make them editable.
Open the Verilog-A views with control + O gives the following error message:
WARNING editFile: X Error of failed request: BadAtom (invalid Atom parameter)
Major opcode of failed request: 20 (X_GetProperty)
Atom id in failed request 0x48
Serial number of failde request 20
Current serial number in output stream: 20
No clue...
I have attached the CDS.log file as a .pdf. There are some warnings and some errors (maybe helpful...)
I am grateful for any help.
Thanks in advance
Jan
bernd
Munich/Germany
Re: Cadence IC5141 editor problems
Reply #1 - Jan 27th, 2009, 2:10am
This sounds to me like an issue with your OS and Cadence IC.
Some suggestion.
1. Contact you Cadence customer support because this is really hard to
   debug through a forum like this.
2. Cadence offers a tool which checks your OS and patches for the
   correct prerequisites for your Cadence installation try it.
   http://sourcelink.cadence.com/docs/files/download/sys_conf_check/
3. Try to set the UNIX environment variable
   csh:
   setenv DD_DONT_DO_OS_LOCKS se
The are some SKILL function which are loaded twice through your setup
function <BlaBal> redefined
also Cadence environment variables s form a different tool version which now are not found any more
  *WARNING* envSetVal: Can't set the value of variable 'BlaBla',
   in tool[.partition] 'schematic' - it has not been registered.
explore where this things are coming from and try to ge rid of theses.
* bernd
Just another lonesome cad guy
bernd
Munich/Germany
Reply #2 - Jan 27th, 2009, 2:12am
Should be
setenv DD_DONT_DO_OS_LOCKS set
* bernd
Reply #3 - Jan 27th, 2009, 12:54pm
