Apr 28th, 2024, 8:59pm
How to generate AM signal in Cadence (Read 3502 times)
DoYouLinux
Feb 05th, 2009, 8:06am
Sounds so easy, but I am still not finding any solution to generate an AM signal using Cadence. Anyone tried this before ?
Thank you very much,
DYL
Re: How to generate AM signal in Cadence
Reply #1 - Feb 5th, 2009, 9:20am
If creating a schematic, use vsource or isource from analogLib. Set source type to be sine, and enter the main frequency and amplitude. Then click on "Display modulation params", and fill in your AM modulation frequency and index (and phase if you want).
You can do the same with the "port" component too.
In spectre, these are just parameters of vsource, isource, or port. Type "spectre -h vsource" for details on the parameters.
DoYouLinux
Reply #2 - Feb 6th, 2009, 8:39am
Thanks a lot Andrew for your help Cheesy
