I just answered a similar question over on comp.cad.cadence .
A few ways you could do this:
1. setenv CDS_LOAD_ENV addCWD This will also look in the working dir for a .cdsenv file. That way you can have it local to the project dir. 2. setenv CDS_LOAD_ENV CSF You can then find the .cdsenv via the setup.loc file mechanism (check in the <instdir>/doc/caiuser/caiuser.pdf for more details) 3. In your .cdsinit do: envLoadFile("./.cdsenv") ; or whatever you want to call the file
