May 4th, 2024, 7:57am
different .cdsenv for different kits? (Read 4156 times)
oermens
Feb 05th, 2009, 8:10am
is it possible to use a different .cdsenv for each of the kits i have installed? although I have customized the .cdsenv in the folder where i launch the kit, cadence only uses the .cdsenv found in my home directory and i have to do all my customizing in that one. this is a problem for things like defining the model path which is unique for each kit.
would .cdsinit be a better means of achieving this? will envSetVal(...) override whats defined in .cdsenv?
thanks.
Re: different .cdsenv for different kits?
Reply #1 - Feb 5th, 2009, 9:04am
I just answered a similar question over on comp.cad.cadence .
A few ways you could do this:
1. setenv CDS_LOAD_ENV addCWD
  This will also look in the working dir for a .cdsenv file. That way
  you can have it local to the project dir.
2. setenv CDS_LOAD_ENV CSF
  You can then find the .cdsenv via the setup.loc file mechanism
  (check in the <instdir>/doc/caiuser/caiuser.pdf for more details)
3. In your .cdsinit do:
  envLoadFile("./.cdsenv")  ; or whatever you want to call the file
oermens
Reply #2 - Feb 5th, 2009, 10:52am
thanks.
