Jul 16th, 2024, 6:01am
PLS help:assura rCX problem (Read 9872 times)
maogecn
Feb 05th, 2009, 7:28pm
Hi, all,
I encounter a problem when I try to use assura to do rcx, the following
is the log file, could anyone give me some suggestion. thanks
Assura (tm) Physical Verification Version av3.1:Production:dfII5.1.41
                            Release 3.1.5
Copyright (c) Cadence Design Systems. All rights reserved.
@(#)$CDS: assura version av3.1:Production:dfII5.1.41 12/23/2005 04:11 (tux21ee)
sub-version 3.1.5
run on dell from /home/mg/tools/cadence/assura315/tools.lnx86/assura/bin/
32bit/assura on Fri Feb  6 10:16:01 2009
Loading tech rule set file : /home/mg/project/csm035/project/verify/assura
/assura_chrt35dg_SiGe_tech/techRuleSets
*WARNING* rcxParameters: ?xyCoordinates is not allowed when ?outputFormat
is dfII. Ignored.
Checking out 1 license for Assura_RCX 3.10
Starting /home/mg/tools/cadence/assura315/tools/assura/bin/rcxToDfII /home/
mg/project/csm035/project/verify/assura/lvs/rcx.inv.rsf -t -cdslib /home
/mg/project/csm035/project/project_2007/cds.lib
@(#)$CDS: rcxToDfII.exe version av3.1:Production:dfII5.1.41 12/23/2005 04:13
(tux21ee) $
sub-version 3.1.5
/32bit/rcxToDfII.exe on Fri Feb  6 10:16:02 2009
Loading libInit.il for chrt35dg_SiGe
Loading context /tmp/libInita03997/chrt35dg_SiGe.cxt
Loading context /tmp/libInita03997/pdkUtils.cxt
Loading  /usr/tools/designkit/csm035/chrt35dg_SiGe/PasLoadPdkParams.ile
Loading PDK Param Table  '/usr/tools/designkit/csm035/chrt35dg_SiGe
/pdkParamTable.ile'
Loading cdsenv file  '/usr/tools/designkit/csm035/chrt35dg_SiGe/.cdsenv'
loading vars from /usr/tools/designkit/csm035/chrt35dg_SiGe/.cdsen
v for tool layoutXL
Loading Display Resources File  '/usr/tools/designkit/csm035/chrt35dg_SiGe/
display.drf'
Loading  /usr/tools/designkit/csm035/chrt35dg_SiGe/libInitCustomExit.il
*WARNING* dbOpenCellViewByType: Failed to open cellView (pres auLvs) from
lib (chrt35dg_SiGe) in 'r' mode because cellview does not exist.
ERROR: Failed to find a cellview for (pres auLvs chrt35dg_SiGe)
ERROR:  Assura is terminating because some library models do not exist.
       Your rules and your dfII model libraries are inconsistent.
       Assura requires all library models in the rule file be present
       in the database when running rcx with the "extracted_view"
       option.
*WARNING* /home/mg/tools/cadence/assura315/tools/assura/bin/rcxToDfII exit
with bad status
*WARNING* Status 256
*WARNING* Assura execution terminated
*****  rcxToDfII fork terminated abnormally  *****
maogecn
View Profile maogecn maogecn   IP Logged
Re: PLS help:assura rCX problem
Reply #1 - Feb 6th, 2009, 2:20am
The error is coming because the extract rules reference a component that does not exist in the library - as it says in the error.
There's an option what was added in 3.1.4 USR1, ?checkCellView nil, which can be added into the RSF to tell it to not do this check. Of course, it will fail if you actually have instances of that component in your layout, but if not it would allow it to proceed.
This also can be found on the Setup tab of the RCX form, labelled "Enable CellView Check".
This is covered in sourcelink solution 11213516 (assuming you have access to sourcelink.cadence.com) - I wrote the solution, actually!
That's quite an old version of Assura you're using there...
maogecn
Reply #2 - Feb 7th, 2009, 11:56pm
Hi, andrew, many thanks for your quick reply.
However, I am just a student of our university, I don't have access to  sourcelink solution 11213516.
so, can you forward it to my email (maogecn@gmail.com)?
thanks
maogcn
maogecn
Reply #3 - Feb 8th, 2009, 2:11am
I don't think there's much more information you could glean from it - it essentially says the same thing as my post. I was merely pointing it out to suggest to you and others that there are often solutions on sourcelink for this kind of thing - although that doesn't help you in your case...
Anyway, you should be able to just turn off the "enable cellview check" checkbox, even with the version you're using. Does that work?
maogecn
Reply #4 - Feb 8th, 2009, 4:01pm
Hi, andrew:
I trurn off the "enable cellview check" checkbox, it still doesn't work.
I post the log files as follow. It seems like above.
           Release 3.1.5
@(#)$CDS: assura version av3.1:Production:dfII5.1.41 12/23/2005 04:11 (tux21ee) $
sub-version 3.1.5
run on gyro.tsinghua.edu.cn from /home/mg/tools/cadence/assura315/tools.lnx86/assura/bin/32bit/assura on Mon Feb  9 07:23:59 2009
Loading tech rule set file : /home/mg/project/csm035/project/verify/assura/assura_chrt35dg_SiGe_tech/techRule
Sets
*WARNING* rcxParameters: ?xyCoordinates is not allowed when ?outputFormat is dfII. Ignored.
Starting /home/mg/tools/cadence/assura315/tools/assura/bin/rcxToDfII /home/mg/project/csm035/project/verify/assura/lvs/rcx.inv.rsf -t -cdslib /home/mg/project/csm035/project/project_2007/cds.lib
@(#)$CDS: rcxToDfII.exe version av3.1:Production:dfII5.1.41 12/23/2005 04:13 (tux21ee) $
sub-version 3.1.5
run on gyro.tsinghua.edu.cn from /home/mg/tools/cadence/assura315/tools.lnx86/assura/bin/32bit/rcxToDfII.exe on Mon Feb  9 07:23:59 2009
Loading context /tmp/libInita08286/chrt35dg_SiGe.cxt
Loading context /tmp/libInita08286/pdkUtils.cxt
Loading PDK Param Table  '/usr/tools/designkit/csm035/chrt35dg_SiGe/pdkParamTable.ile'
loading vars from /usr/tools/designkit/csm035/chrt35dg_SiGe/.cdsenv for tool layoutXL
Loading Display Resources File  '/usr/tools/designkit/csm035/chrt35dg_SiGe/display.drf'
*WARNING* dbOpenCellViewByType: Failed to open cellView (presistor auLvs) from lib (chrt35dg_SiGe) in 'r' mode because cellview does not exist.
ERROR: Failed to find a cellview for (presistor auLvs chrt35dg_SiGe)
       option.
*WARNING* /home/mg/tools/cadence/assura315/tools/assura/bin/rcxToDfII exit with bad status
maogecn
Reply #5 - Feb 9th, 2009, 2:03am
Do you have analogLib in your cds.lib? It's looking for presistor now, which is normally not part of the design kit...
Otherwise, you should probably contact the PDK provider.
maogecn
Reply #6 - Feb 9th, 2009, 4:28pm
yes, I do have analogLib include in my cds.lib.
It still can't work.
however, thank you very much for your kindly reply.
maogecn
