The error is coming because the extract rules reference a component that does not exist in the library - as it says in the error.
There's an option what was added in 3.1.4 USR1, ?checkCellView nil, which can be added into the RSF to tell it to not do this check. Of course, it will fail if you actually have instances of that component in your layout, but if not it would allow it to proceed.
This also can be found on the Setup tab of the RCX form, labelled "Enable CellView Check".
This is covered in sourcelink solution 11213516 (assuming you have access to sourcelink.cadence.com) - I wrote the solution, actually!
That's quite an old version of Assura you're using there...
