Jul 19th, 2024, 10:30am
[q] in ocean script (Read 1379 times)
kidhyun
[q] in ocean script
Feb 12th, 2009, 12:00am
Dear all,
     I am using ocean script in spectre simulation.
     I copied some OP point parameters in array. (I used foreach to run several op analysis)
     Is there any way that I can plot this array?
     (since this array is not waveform, i wasn't able to use plot command)
     I also hope if there is a way of using array for x-axis variable.
Thank You
Re: [q] in ocean script
Reply #1 - Feb 12th, 2009, 4:39am
http://www.eecs.tufts.edu/~ryun01/gmid_ruida.pdf
http://www.designers-guide.org/Forum/YaBB.pl?num=1228854029/1#1
You can change array to list. And you can change list to vector.
Also you can use vector directly without using list.
   ;Get Memory for Work Area
   declare( a[n] );
   declare( b[n] );
   for(i, 0, n-1
      drSetElem(a_vec, i, a[i]);
« Last Edit: Feb 12th, 2009, 5:47am by pancho_hideboo »
Reply #2 - Feb 12th, 2009, 1:17pm
If it's a list, there's also the awvPlotList() function which can be passed a list of x-values and a list of y-values (if my memory is correct, it's a list of lists of y-values) without needing to construct waveform objects first.
kidhyun
Reply #3 - Feb 12th, 2009, 4:34pm
Thank you for the answer.
avlsi
singapore
Reply #4 - Feb 13th, 2009, 12:52am
After using getAsciiWave function, i am getting a drwave:47823452.
What is the procedure to obtain waveform?
Thanks.
Winners never Quit,Quitters never Win
Reply #5 - Feb 13th, 2009, 2:15am
That is a waveform. I presume you want to plot the waveform? If so, do:
plot(getAsciiWave(...))
or assign to a variable first:
data=getAsciiWave(...)
plot(data ?expr '("my data"))
avlsi
singapore
Reply #6 - Feb 15th, 2009, 5:52pm
Thanks Andrew. I could plot the waveform using ur advice.
