Jul 16th, 2024, 10:19pm
how to simulate CSO & CTB with spectre (Read 7988 times)
wwm101
china
Feb 14th, 2009, 4:46am
CSO & CTB are the most important parameters for the CATV system.
how to simulate them with spectre?
thank you in advance.
ps:
CSO:Composite Second Order
CTB:Composite Triple Beat
View Profile wwm101 weiming022002@yahoo.com   IP Logged
Re: how to simulate CSO & CTB in cadence
Reply #1 - Feb 14th, 2009, 4:52am
If you have Agilent ADS, see "/examples/Com_Sys/CATV_prj"
http://cp.literature.agilent.com/litweb/pdf/ads2005a/examples/comsys/CATV.html
This project demonstrates how ADS can be used to measure the impact of a broadband amplifier
in a CATV system with examples of how to compute the Composite Triple Beat
and how to predict the Composite Second Order of a broadband amplifier.
It includes NTSC and PAL system video source designs to simulate video circuits and transmission.
I can't access Agilent ADS now.
Maybe you can do same tasks in Cadence Spectre.
When I have time, I will check whether this ADS examples can be realized in Cadence Spectre.
wwm101
china
Re: how to simulate CSO & CTB with spectre
Reply #2 - Feb 14th, 2009, 5:10am
the content cut from a Digital TV Signal Analyzer user manul.
http://www.konturm.ru/catalogy/paspeng/17series%20manual(English).pdf
wwm101
china
Reply #3 - Feb 14th, 2009, 5:19am
to: pancho_hideboo
thank you very much for your attention &suggestions。
i‘ll try .
als
Shin Yokohama, Japan
Reply #4 - Feb 14th, 2009, 8:01pm
Greetings,
  Spectre RF QPSS analysis has been enhanced to support CBT analysis, attached are
the results for a 132 channel example. I have not tried simulating CSO but simulating
it should not be a problem either.
        Art Schaldenbrand
Reply #5 - Feb 15th, 2009, 2:23am
als wrote on Feb 14th, 2009, 8:01pm:
Spectre RF QPSS analysis has been enhanced to support CBT analysis.
I can't find any special enhancement even in "Spectre RF New Features in MMSIM 7.1.0".
What feature is enhanced ?
In Agilent ADS, I can set any multiple tones easily in Voltage or Power Sources since their frequencies and amplitudes(powers) are defined as array.
But there are only two tones setting in Cadence "analogLib/vsource" and "analogLib/port".
Just enhancement of ability to set multiple tones in vsource and port such as 131 tones ?
« Last Edit: Feb 15th, 2009, 6:14am by pancho_hideboo »
Reply #6 - Feb 15th, 2009, 5:17am
Pancho Hideboo,
The enhancement was back in MMSIM61 - it was to support the "freqvec" parameter on sources, to allow many tones to be specified, with (say) one missing. This is then understood by QPSS.
Unfortunately there's rather limited documentation for this.
Reply #7 - Feb 15th, 2009, 5:50am
Spectre RF New Features in MMSIM 6.1
Composite Frequency Simulation
Spectre primitive sources are enhanced to support composite frequency (for example, composite triple beat, missing tone) simulation.
wwm101
china
Reply #8 - Mar 5th, 2009, 6:22am
to:als
how to  realize it  with  ic5141? can you give some examples.
thank you .
