Aug 16th, 2024, 12:31pm
amplifier with "Dynamic Gain" (Read 1845 times)
buddypoor
Bremen, Germany
Feb 14th, 2009, 5:18am
Hello to all,
has anybody heard about an amplifier parameter called "dynamic gain" defined in the TIME domain as the ratio of output to input voltage ?
This definition would lead to a gain variation between zero and infinite, because input and output are going through zero at different times for real amplifiers with phase shift.
Thank you.
Regards to all.
Buddypoor
vivkr
Re: amplifier with "Dynamic Gain"
Reply #1 - Feb 19th, 2009, 3:12am
I don't know if this is what you mean but there are amplifiers used in sensing and detection applications which are based on radar principles. Here, you may be trying to "sound" a material to observe its structural properties.
In order to partially compensate for the variations in attenuation levels experienced by signals reflected from near and far targets, the gain of the amplifier is usually increased with time, starting from an initial value (when near target echos arrive) to a larger final value (when far target echos arrive at the receiver).
However, I don't know if the term "dynamic gain" is used here. If you are more interested, just read some apps on ultrasound applications.
Vivek
buddypoor
Bremen, Germany
Reply #2 - Feb 19th, 2009, 8:16am
Hello vivek,
thank you for your reply and your attempt to clarify my question.
In principle, my question concerns an amplifying device and - more or less - you have confirmed my assumption that it makes no sense to define a parameter as mentioned in my first post.
This parameter "dynamic gain" was mentioned by an experienced man during a conversation/discussion with me and I doubt if it makes sense to calculate in the time domain the ratio of momentary values of output and input voltages.
Thank you and regards
