sure, of course, following is the instantiation line. I will check the sourcelink solution you mentioned.
Thanks!
Andres
_______________________________
CELL_NAME (*
integer library_binding = "LIB_NAME";
IPULL ( .dn3( dn3 ), .TUD( TUD ), .nwelle( \vdde3v3! ), .PAD(
net83 ), .nwell( \vdd! ), .up3( up3 ), .VREFH( VREFH ), .psub( \gnd! ),
.bulk( \gnde! ) );
Andrew Beckett wrote on Feb 17th, 2009, 8:03pm:Can you post the instance line for IPULL from the netlist?
This may be a CDF parseAsNumber issue - see sourcelink solution 11086400.
