Aug 15th, 2024, 10:13am
ncsim error during circuit read-in - AMS running from HED (Read 3466 times)
raftman
Feb 16th, 2009, 5:00pm
My design is elaborating ok, but after ncsim launches the simulation never begins and the following error is in my ncsim.log
Error found by spectre during circuit read-in.
    test_TOP.IADC.IO.I33.IPULL: error in evaluating parameter 1.
spectre terminated prematurely due to fatal error.
_______________________________--
I've looked through the verilog.ams netlists for cell I33 (which instantiates IPULL) and IPULL and not seeing anything with a parameter named, or set to, 1.  I also looked at the properties in the schematic and haven't found anything.
anyone know where I might look for more information about what's causing spectre to stop?
Re: ncsim error during circuit read-in - AMS running from HED
Reply #1 - Feb 17th, 2009, 8:03pm
Can you post the instance line for IPULL from the netlist?
This may be a CDF parseAsNumber issue - see sourcelink solution 11086400.
raftman
Reply #2 - Feb 18th, 2009, 8:35am
sure, of course, following is the instantiation line.  I will check the sourcelink solution you mentioned.
Thanks!
Andres
CELL_NAME (*
integer library_binding = "LIB_NAME";
IPULL ( .dn3( dn3 ), .TUD( TUD ), .nwelle( \vdde3v3!  ), .PAD(
net83 ), .nwell( \vdd!  ), .up3( up3 ), .VREFH( VREFH ), .psub( \gnd!  ),
.bulk( \gnde!  ) );
Andrew Beckett wrote on Feb 17th, 2009, 8:03pm:
Reply #3 - Feb 20th, 2009, 11:46pm
What about the module definition for IPULL? (the instance line didn't reveal much, other than that there were no parameters).
