Dan Clement
Salt Lake City, Utah, USA
The resistors steal current from the bipolars and that will affect the tempco. I could understand that one would tweak these resistors to get the tempco they want.
However, mismatch will be a killer and would probably remove any benefit of the tweaking.
Are the resistors even necessary? If not, remove them.
The tempco of these resistors also impacts the temperature curve, so if you can get rid of them you should.
Regards, Dan
