Sep 28th, 2024, 4:12am
SC-CMFB: Which Phase CM voltage is important (Read 3466 times)
neoflash
Mixed-Signal
Designer
Feb 18th, 2009, 5:17am
I have a question that, in switched capacitor integrator design, the SC-CMFB should regulate CM voltage in which phase?
Integration phase or sampling phase?
Any suggestion on literature sample?
Berti
Re: SC-CMFB: Which Phase CM voltage is important
Reply #1 - Feb 18th, 2009, 11:24pm
I am not sure whether I understand your question correctly.
But I think that the CM voltage is regulated in both phases anyway.
Cheers
Sarig
Reply #2 - Mar 10th, 2009, 1:28pm
It doen't improtent as long as your Amp keep the CM in place. and it should do so in both phases because your final results depands on both phases.
Erez
yvkrishna
Reply #3 - Apr 25th, 2009, 4:47am
Hi Neoflash,
I think this is what your doubt is about..
The SC CMFB corrects the output CM voltage in sampling phase, in the integration phase the inputs are applied and the output commonmode gets slightly corrupted, which again is taken care of in the succeeding sampling phase.
vamshi
