Are you planning to simulate it in spectre, or AMS Designer (mixed-signal)?
If spectre, then one way would be to simulate in ADE, and then plot the outputs of your ADE in Wavescan/ViVA (depending on the version you're using). Then select the output waveforms in the graph and hit the "a2d" icon. On the resulting form, you can specify the thresholds for low and high, and when you OK this, it will generate digital traces for these signals. You can then select all of these in the waveform window, and hit the "table" icon. OK the resulting form, and you'll see the 1/0/x info for each signal versus time.
You can then do a File->Save As CSV if you want to get it into a comma-separated-value file.
It wasn't clear what you wanted to do with the data, but hopefully this will give you a few hints?
