Aug 16th, 2024, 10:22am
Delay locked loop -- reconfigurable phase selection (Read 1474 times)
taofeng
Belgium
Feb 25th, 2009, 2:35am
I hope I could have some real help from the DLL experts in this forum. Let me first describe my problem referring to the attached file.
Basically I want to make a Delay Locked Loop. However, the delay lines inside the loop are composed of (1-delta%) and delta% which give the total 100% delay (or 2*pi) phase shift. Then I want to make a tap selection from the part of the delta%.
The question is how to design this delay cell and how to further make the delta% reconfigurable, for instance I can easily change the percentage of delta (for instance from 5% to 20%).
thank you for your help !
Jef
Re: Delay locked loop -- reconfigurable phase selection
Reply #1 - Feb 25th, 2009, 11:15pm
Hi Jef,
Assume the delay line 1-Δ% and Δ% contain 100 delay cells. The right most delay line in your schematic needs 20 delay cells, where one of the outputs is chosen using a multiplexor. Be careful to make the load of all the 120 delay cells balance.
Yawei
