Aug 15th, 2024, 8:21am
Laser-Metal-Fuses (Read 2737 times)
Berti
Laser-Metal-Fuses
Feb 25th, 2009, 4:55am
Dear all,
I have studied the following post:
http://www.designers-guide.org/Forum/YaBB.pl?num=1215137612/4#4
However, for the technology I am using the given off-resistance of a (metal-)laser-fuse is very high (>1MΩ). I am wondering if I the off-resistance might be much lower (due to e.g. splattered metal)? I also wonder how much distance I should keep between fuse and circuit (e.g. vt-shift due to heat from laser?).
Does anybody has experience?
