I'm building a pipeline ADC... usually in the sampling phase, the amplifier is tied in unity-gain configuration. However, I'm using a fully-differential telescopic amplifier with output cmomon mode = 1.3V and input common mode = 0.9V... I've searched the literature but cannot find a thing relating to what the amp is to do when the caps are sampling.... it can't be put into unity gain as normal. I use SC-CMFB which tried to keep the output at 1.3V during the sampling, but right now the amplifier is open-loop during sampling, which is not ideal... any hints?
Putting a cap in the feedback during this phase doesn't do much, right... sure doesn't cature the d.c. offset voltage - only works at high frequencies. Perhaps a source-follower in the feedback? Something else?
I've also found little literature on the topic of amp measurments when using an amp which different input and output common modes. What I do for gain/phase is the usual resistor and cap round the feedback to set up d.c. but block a.c. - though of course there is a little current flowing through the resistor due to the difference in common-mode levels - I don't think this is too much of a problem? Anyway, thanks for any help!
EDIT - One paper I see has simply shorted the output of the amplifier to the required output common-mode voltage - good approach? I'm thinking of currents entering the bias circuitry here..
