Jul 16th, 2024, 3:43pm
4 bit multiplier in simulink (Read 291 times)
c1000
Mar 03rd, 2009, 5:04am
I am modelling transmitter using simulink.
for the digital system, I need full adder and multiplier for 4bit input signals. but i didnt find any blocksets for it.
should I use the "bit operator" to form the full adder, 4bit adder, 4bit multiplier by myself?
I  just want to avoid unnecessary effort.
Re: 4 bit multiplier in simulink
Reply #1 - Mar 3rd, 2009, 5:13am
Use Fixed_to_Int and add as multiply and then Int_to_Fixed.
c1000
Reply #2 - Mar 3rd, 2009, 5:21am
sorry, i dont catch you....
i dont need to bulid those models like real circuits?
could you explain it in detail?
Thank you very much!!!
a little urgent for me....
Reply #3 - Mar 3rd, 2009, 5:27am
c1000 wrote on Mar 3rd, 2009, 5:21am:
How degree do you know signal processing simulator such as Simulink(MATLAB), Ptolemy, SystemVue, SPW(CoWare Signal Processing Designer, SPD), etc. ?
You don't have to bulid as real circuits.
Each block have output data type setting.
And there is Data Type Conversion Block in "Simulink/Signal_Attributes".
c1000
Reply #4 - Mar 3rd, 2009, 6:00am
I am a beginner for simulink
so easy to get confused...
that's why i need detailed explanation, sorry...
i need to multiply the output of adc (4 bit or 8bit ) and then subtract one by one.
Reply #5 - Mar 3rd, 2009, 5:14pm
c1000 wrote on Mar 3rd, 2009, 6:00am:
What tool are you familiar with ?
Use ideal DAC and ideal ADC.
