Jul 18th, 2024, 11:20pm
How to design Analog multiplxer? (Read 4125 times)
Mahavir
India
Mar 10th, 2009, 10:47am
As a part of my dissertation, I need an anlog mux that will pass different DC voltage levels based on the select line inputs. These are fixed dc levels. I used a very simple conept of pass transistor logic with decoder on top to turn on particular switch as shown in diagram. The AS in diagram means Analog Switch.But i am facing problem in output stage.
How can I make the signal flow unidirectional? Is pass transistor logic for Analog Switch suitable one?
Also is there any other way to design the analog mux?
Plz reply,
Thanks in advance.
View Profile WWW Mahavir   IP Logged
HdrChopper
Re: How to design Analog multiplxer?
Reply #1 - Mar 10th, 2009, 6:29pm
what is wrong with using TX gates in your desing?
Keep it simple
Reply #2 - Mar 12th, 2009, 2:35am
Mahavir,
What is "unidirectional" here? What's your problem?
Yawei
subgold
Reply #3 - Mar 16th, 2009, 8:03am
why you need to force the mux to be unidirectional? what kind of following and preceeding stages does the mux have? if unidirection is really necessary, an output buffer seems to be enough?
whether the switch is suitable depends on the voltage levels of the input, output and the switching signal. If the switch can always be completely turned on, then it should be ok.
Mahavir
India
Reply #4 - Mar 22nd, 2009, 2:17pm
Hi All,
Sorry for late reply.
Actually, the inputs to the transmission gate are constant dc voltage levels. I figured out what my problem is. The transistors in tx gate are not getting turned on at same instant. and so one of the transistor is causing drop which of equal amount as threshold. I think i need to design a inverter fork. Currently I am working on the possible width ratios.
But problem remains. Since dc voltage levels are inputs and some of them are smaller than threshold of transistor, what effect will they cause? Since all outputs are connected together at one node, what will happen when a particular tx gate turns off and other turns on?
Need help
Plz reply.
Reply #5 - Mar 24th, 2009, 9:01pm
Since the tx gates are composed of NMOS and PMOS, the dc voltage levels go to the output without any loss even if they are smaller than the threshold of transistors.
The input signals will conflict if only one tx gate off and others on.
Yawei
