mydreamhouse wrote on Mar 18th, 2009, 11:01am:what i worry about is the third order distortion of IF signal mixes that of the second LO.
for instance, the IF is 200MHZ, after external LC BPF or SAW filter, an on chip IF VGA is following.
due to the third order intermodulation of IF VGA, third order distortion will be appears before the second mixer.
so 3IF-3LO will be in band(dual conversion superheterodyne receiver),which will degrade the sensitivity.
Still there is no one who can understand a meaning of your sentences.I can't know your system is double super heterodyne until now.
And third order harmonic distortion is different from distortion due to third order intermodulation.
Do you understand third order intermodulation correctly ?
Again If you want someone to answer your post,
you have to describe your questions regarding situation and condition in detail and correctly using industrial standard terminologies.
