May 1st, 2024, 12:26am
How to measure HD3, THD, IIP3, IIM3 in cadence (Read 8848 times)
david
Mar 16th, 2009, 5:55am
hello !!
how can i measure HD3 ,THD, IIP3, IIM3 using cadence analog environment for cmos ota design
please reply soon......its urgent
thanks in advance  :)
Re: How to measure HD3, THD, IIP3, IIM3 in cadence
Reply #1 - Mar 16th, 2009, 6:27am
Your question is no more than very specific EDA vendor's Tool Play not Measurement Issues.
david wrote on Mar 16th, 2009, 5:55am:
how can i measure HD3 ,THD, IIP3, IIM3 using cadence analog environment for cmos ota design.
I don't know "IIM3". What is "IIM3" ?
First of all, do you understand definitions of HD3 ,THD, IIP3, IM3 correctly ?
How degree are you familiar with Cadence Spectre and ADE ?
How do you evaluate the above characteristics ? DFT using Transient Analysis or PSS(QPSS) ?
Can you write Ocean Script ?
See http://www.designers-guide.org/Forum/YaBB.pl?num=1220511510/0#0
If you understand definitions of HD3 ,THD, IIP3, IM3 correctly, you can evaluate them whatever analysis you use such as Transient, PSS(QPSS).
Your following question is also no more than very specific EDA vendor's Tool Play not Design Issues.
http://www.designers-guide.org/Forum/YaBB.pl?num=1237208368/0#0
Tiger
Reply #2 - Apr 3rd, 2009, 12:22am
thanks a lot pancho hideboo
