Jul 18th, 2024, 7:24am
Problem with HSPICE (Read 4273 times)
pgbackup
Problem with HSPICE
Mar 16th, 2009, 9:00am
I'm running the latest HSPICE release from Synopsys: hspice-C-2009.03.
I have a model for a carbon nanotube transistor developed by a university. I am trying to simulate a basic inverter.  I run my the simulation as follows: 'hspice inv.sp >run.log'.
I'm getting an error. Upon examining run.log, I see the following errors:
**error** the output variable used in the algebraic equation of element
   7:gbtbt            does not exist.
   7:g_qtotal         does not exist.
   7:g_qchannel       does not exist.
When I dig in closely to the model, the above errors result from these lines (in cnfet.lib):
GCNT         Drain        Source        CUR='JFET(V(Drain,Source),photon,V(phib,Sub))'
GBTBT      Drain        Source          CUR='J_btbt(V(Drain,Source),I(GCNT),V(phib,Sub))'
G_Qtotal         Vdrain     phib        CUR='charge_channel(V(Vdrain),V(Vgate),V(Vsource),V(VsubM),V(phib,Sub))'
G_Qchannel       phib       Sub         CUR='charge_total(V(Vdrain),V(Vsource),V(phib,Sub))'
GCNT       Source       Drain           CUR='JFET(V(Vdrain,Vsource),photon,V(phib,Sub))'
GBTBT      Source       Drain           CUR='J_btbt(V(Vdrain,Vsource),I(GCNT),V(phib,Sub))'
The current version of HSPICE doesn't like the fact that CUR is not defined as a variable? Since I'm not an expert in SPICE, I'm not sure how I can fix this problem.
I was able to simulate this circuit fine in and older HSPICE release without any problems.
Can someone tell me how I fix the above  problem? I tried adding .PARAM CUR to the cnfet.lib file but that didn't fix it.
I'm also attaching the complete files if anyone wants to see
Thanks for any ideas.
pgbackup
Re: Problem with HSPICE
Reply #1 - Mar 16th, 2009, 9:02am
The files are attached. Its cnfet.zip
Reply #2 - Mar 16th, 2009, 2:28pm
It looks like it's not complaining about GCNT, which also uses CUR, so either you didn't put in all the errors (don't know why you put in 3 if not all), or else CUR isn't the problem.
Is J_btbt defined properly?  I see this in the lib file you uploaded:
.PARAM J_btbt(Vds,Ids,phib)='coeffj*kT*(Jbtbt_sub_1(Vds,Ids)*Tbtbt1(Vds,phib) + \\
                                       Jbtbt_sub_2(Vds,Ids)*Tbtbt2(Vds,phib))'
Maybe the new version doesn't like th \\ newline inside the 'quotes' ?
pgbackup
Reply #3 - Mar 16th, 2009, 7:28pm
Hi Geoffrey,
Thanks for taking the time to respond.
I agree it is not complaining about GCNT. run.log contains all the errors that hspice lists outs.
Since I have not written the model, I am not sure if the syntax is correct. However, I was able to simulate using this library on a 2007 version of HSPICE. I have contacted the developers to see if they can help fix this issue.
I looked at the "\\" and tried removing it but to not avail. There were also two spaces "  +" before the plus sign. But that didn't seem to work either.
spiceoracle
USA
Reply #4 - Apr 13th, 2009, 1:43pm
I'm not sure what the problem is.
I've run your testcase using HSPICE C-2009.03 on a number of different machines.  HSPICE runs successfully and does not give the error messages that you have seen.  The only difference I see is that the machine that I used that is similar to the one that you used is the OS version.
pgbackup
Reply #5 - Apr 30th, 2009, 9:53pm
Thanks for taking the time to try the test case out. I was able to solve this problem a few back. I was running Fedora 10 and the problem was happening. This OS is not supported by Synopsys. I switched to Red Hat Enterprise Linux 4 (which is supported) and the problem was gone. I guess it must have been some string processing/parsing libraries causing the strange errors.
On the other hand, I guess when EDA vendors means they only support a particular OS, they really mean it  :)
