Did you try reading the manual?
With IC612/IC613 you should be able to either invoke "cdnshelp" from the command line, or use the Help menus in the tools to navigate the help system.
Worst case, take a look at <ICinstDir>/adexl/adexl.pdf
In the version I looked at (latest IC613 ISR), Chapter 7 is "Performing Monte Carlo Analysis".
