pgbackup
I'm running the latest HSPICE release from Synopsys: hspice-C-2009.03. I have a model for a carbon nanotube transistor developed by a university. I am trying to simulate a basic inverter. I run my the simulation as follows: 'hspice inv.sp >run.log'.
I'm getting an error. Upon examining run.log, I see the following errors:
**error** the output variable used in the algebraic equation of element 7:gbtbt does not exist.
**error** the output variable used in the algebraic equation of element 7:g_qtotal does not exist.
**error** the output variable used in the algebraic equation of element 7:g_qchannel does not exist.
When I dig in closely to the model, the above errors result from these lines (in cnfet.lib):
GCNT Drain Source CUR='JFET(V(Drain,Source),photon,V(phib,Sub))' GBTBT Drain Source CUR='J_btbt(V(Drain,Source),I(GCNT),V(phib,Sub))' G_Qtotal Vdrain phib CUR='charge_channel(V(Vdrain),V(Vgate),V(Vsource),V(VsubM),V(phib,Sub))' G_Qchannel phib Sub CUR='charge_total(V(Vdrain),V(Vsource),V(phib,Sub))' GCNT Source Drain CUR='JFET(V(Vdrain,Vsource),photon,V(phib,Sub))' GBTBT Source Drain CUR='J_btbt(V(Vdrain,Vsource),I(GCNT),V(phib,Sub))'
The current version of HSPICE doesn't like the fact that CUR is not defined as a variable? Since I'm not an expert in SPICE, I'm not sure how I can fix this problem.
I was able to simulate this circuit fine in and older HSPICE release without any problems.
Can someone tell me how I fix the above problem? I tried adding .PARAM CUR to the cnfet.lib file but that didn't fix it.
I'm also attaching the complete files if anyone wants to see
Thanks for any ideas.
