Aug 16th, 2024, 5:17am
question about crystal oscillator (Read 2883 times)
hyy95
Mar 17th, 2009, 7:25pm
I have some questions about the feedback resistor in the pierce oscillator setting:
why can it force the transistors into active region?
why it's value should be high?
how does a low value Rf degrade the frequency stability?
how does a low value Rf increase the current?
how can we find the best value of Rf?
Re: question about crystal oscillator
Reply #1 - Mar 17th, 2009, 9:10pm
hyy95 wrote on Mar 17th, 2009, 7:25pm:
Since it forces input and output to same voltage.
Since it is negative feedback resistor.
Rather if Rf is too small, oscillation will not start up.
It Rf is too small enough not to start up oscillation, static DC current is consumed at inverter where both NMOS and PMOS are on state.
It depends on oscillation margin and drive current for crystal.
hyy95
Reply #2 - Mar 17th, 2009, 9:25pm
I don't get this one, can you explain more details? Thanks!
Why won't the oscillation start up, can you explain in details? Please!
[/quote]
can you share more details on this one? How do you derive the Rf value based on oscillation margin and drive current for crystal. Or can you point me to a paper that discuss this in details? Thanks!
Reply #3 - Mar 17th, 2009, 10:12pm
hyy95 wrote on Mar 17th, 2009, 9:25pm:
These are too basic issues. So read circuit theory text book for beginner.
I'm not kind and patient enough for explaining such too basic issues.
Maybe someone who is very kind and patient will help you.
« Last Edit: Mar 17th, 2009, 11:59pm by pancho_hideboo »
