This should be possible. When using design() to point at a netlist, the netlist has to be called "netlist", and you need to have files alongside it called "netlistHeader" and "netlistFooter" (which can be empty). Having done that, it should be possible to simulate using OCEAN.
Perhaps (after trying the above) you can show what errors you got?
