Aug 17th, 2024, 1:08am
Power negative resistance (Read 196 times)
masoud
Mar 23rd, 2009, 7:54pm
Hi everybody,
Actually I am looking for a circuit of a negative resistance. I need it to work in DC and AC forms. and it should be capable to bear up to 20A (DC) for about 1sec.
I will appreciate if anybody can help me.
Thanks a lot,
Masoud
raja.cedt
Re: Power negative resistance
Reply #1 - Mar 23rd, 2009, 8:53pm
i think this   -ve resistance is  a small signal quantity,for 20A i am not sure whether it will come or not.Actually why u want such a high current rating -ve R?
regards,
Rajasekhar.
masoud
Reply #2 - Mar 23rd, 2009, 8:58pm
It can be done using opamp but it is not suitable for such a current so it should be done using the power transistors but I can not find proper topology because most of the transistor based topologies have -ve R in small signal and in the most cases the input current is going through the Base pin which can not bear 20A even for couple of miliseconds.
What is your idea?
It is good if I can do that for only 40-60 miliseconds for DC current
buddypoor
Bremen, Germany
Reply #3 - Mar 24th, 2009, 12:50am
APEX sells power opamps with output currents up to 30 A.
I see no reason why the classical NIC shouldīt work at such high currents. Itīs not only a small signal device.
Try a simulation with one of APEX opamps.
raja.cedt
Reply #4 - Mar 24th, 2009, 1:30am
hi buddy poor,
                      i have question based on the your reply,even for ordinary NIC,-ve property is narrow in property i mean to say that over a small voltage range only its possible.Then how its possible for very high current,because with this high current range transistors are good  only for switch purpose's rather in linear region.correct me if am wrong.
rajasekhar.
masoud
Reply #5 - Mar 24th, 2009, 10:19am
Hi Raja,
The thing you said is the main problem, ordinary transistor based -ve R are only working in small signals and I want to know if there is any topology which can produce -ve R using transistors to have -ve R even in DC mode. DC is more important than AC condition for me I mean I want a -ve R which works in DC and 20A current.
@buddy poor: thanks a lot for introducing that OpAmp it is a very good one which i didn't know thanks a lot.
raja.cedt
Reply #6 - Mar 24th, 2009, 9:22pm
hi,
   i really surprised about -ve R at dc,can u please tell  me about the application where you want to use this, because if u you are using an non inverting amplifier with +ve feedback it may possible(provided op amp has  zero common mode voltage at the input),any how i don't know much..may be with your we can figure out ...
Rajasekhar.
