Andrew Beckett wrote on Mar 31st, 2009, 3:18am:I presume you don't really mean phase noise? For that you'd use pnoise analysis.
To find the transfer function from a perturbation on the supply to the output of the VCO, you'd use PXF, as Ken says. There is also the "modulated" mode of PXF, which allows you to separate the PM and AM components of the modulation - some of the supply variation may not affect the frequency, but just the amplitude - so being able to separate them may be useful.
To run PXF, you wouldn't apply any varying signal on the supply - you'd tell PXF where the output of the circuit is, and the output frequency (much as you'd specify the output for pnoise). Then when the simulation is finished, you can use the direct plot form to click on the source for the supply, and see the transfer function(s) from this source to the outputs.
Hello Andrew, I have the same question as Sivan's.
Since PXF gives us the transfer function from the power supply to the output of VCO, we only get to know VCO's power supply sensitivity, which is not the phase noise due to the ripple on supply path.
And in the "modulated" mode in PXF, even when PM is chosen in "Main Form", I only get the phase component of modulation from power supply to output of vco, not the phase noise yet.
Do you have any idea to change this result to the phase noise contributed by supply noise?
Yutao
