Aug 18th, 2024, 11:25pm
load transient response improvement of LDO (Read 6542 times)
khajaahmad
Mar 27th, 2009, 6:35am
hi, i need to find a relationship between open loop phase margin of LDO
and closed loop load transient response of LDO, but for the problem i am facing is for my LDO input is constant but load is changing , so which open loop transfer function I should take is it Vo(s)/Vi(s), by simply breaking the loop and applying Vi at input positive input of error amplifier or it is other thing????
thanks in advance .
My LDO is attached here.
HdrChopper
Re: load transient response improvement of LDO
Reply #1 - Mar 27th, 2009, 7:54pm
The open loop gain over frequency for your LDO will also set the output impedance of your LDO over frequency.
Such output impedance will be the one setting the response to the load variations on your regulated line.
So you should run and ac analysis and analyzing VO(s) / Io(s) where Io (s) is the current entering the output node of the LDO.
After than you can characterize the LDO response to load variations by considering the output impedance it is presenting to the external load.
Regars
Tosei
Keep it simple
raja.cedt
Reply #2 - Apr 6th, 2009, 12:38pm
hi,
  i didn't get your question properly,if you make output pole dominant and keep first non dominant pole at  2* times of the UGB,then you can directly find the relation.if you have any question,please let me know.
rajasekhar.
bharat
Reply #3 - Apr 13th, 2009, 8:53pm
Tosei,
The Io(s) is keep on varying from 2 mA to 10 mA. Therefore when you say VO(s) / Io(s), Io(s) is vriable.
Also, even if going for worst case Io(s); for pole location 10mA is worst case, for gain margin 2mA is worst case.
Rajasekhar,
The dominant pole is not fixed if we make output as dominant, because due to change in current the pole location will move and hence UGBW and hence Phase Margin.
HdrChopper
Reply #4 - Apr 14th, 2009, 7:07pm
bharat wrote on Apr 13th, 2009, 8:53pm:
Tosei,
Hi bharat,
What you are suggesting as different levels of Io (2-10ma) are different quiescent points and correspond to large signal conditions. When referring to Io(s) I was referring to small signal conditions, which is the one that corresponds to consider when analyzing poles location, stability, etc.
Ideally such stability conditions should be analyzed for ANY possible quiescent point.
Hope this helps
Tosei
Keep it simple
raja.cedt
Reply #5 - Apr 15th, 2009, 6:43am
hi Tosei,
            even i got same thought.so by finding stability using poles/zeros we are assuming that all bias voltages/currents are fixed....my question is do we have to run for all bias voltages are any other way to get rid of many simulations?But if i know that i am using my circuit for a particular range of bias then its fine,i can run for those simulations  only.Lets say in this regulator at what current we have to simulate?I think at higher current less loop gain and low frequency pole will come,so this is the best case, so if i simulate at low current thats fine?
 correct me if am wrong
Rajasekhar.
HdrChopper
Reply #6 - Apr 15th, 2009, 5:57pm
raja.cedt wrote on Apr 15th, 2009, 6:43am:
hi
Hi Rajasekhar,
In theory you should run the ac or stability analysis for ALL the possible operation quiescent points. However the vast majority of the circuits that work under a certain range of quiescent points behave in such a way that usually it suffices with analyzing stability at the extremes of such range. This approach assumes the stability variations accross the different operation quiescent points is gradual on monothonic. If these requirements were not met then you might be missing a stability condition at a particular quiescent point that could be critical.
I think for the case of the LDO you should be fine by checking the stability at the extremes of the Io range.
Tosei
Keep it simple
