Verilog-AMS
Analysis
Modeling
Design
Theory
Welcome, Guest. Please
Login
or
Register.
Please follow the Forum
guidelines
Aug 17
th
, 2024, 1:19pm
Home
Help
Search
Login
Register
PM to admin
Design
Analog Design
› Switched Capacitor Channel Select Filter
Previous topic
Next topic
Switched Capacitor Channel Select Filter (Read 1788 times)
aaron_do
Mar 30
th
, 2009, 1:27am
just wondering, is there any major reason why we wouldn't use a switched capacitor filter for a channel-select filter for a direct-conversion receiver? Suppose the filter needs to work with a signal as low as -80 dBm.
thanks,
Aaron
IP Logged
rf-design
Reiner Franke
Re: Switched Capacitor Channel Select Filter
Reply #1 -
Mar 30
th
, 2009, 1:56am
The reason is that there are alternatives with better efficiency.
For inband noise/power dominated designs the cap size is equal in continuous-time and switch cap filters.
But the sampling frequency should be a factor higher than the maximum rejection frequency. Otherwise rejection is limited by alias. Second to have an accurate frequency response the caps should charged within a fraction of the sampling period. The need much more current again. If you compare the required bias current of continuous versus discrete filter opamps there is a big factor.
That rules out switch cap!
IP Logged
aaron_do
Reply #2 -
Mar 30
th
, 2009, 7:45am
Thank you very much.
IP Logged
Previous topic
Next topic
Forum Jump »
» 10 most recent Posts
» 10 most recent Topics
Design
- RF Design
»» Analog Design
- Mixed-Signal Design
- High-Speed I/O Design
- High-Power Design
- Mixed-Technology Design
Analog Verification
Measurements
- RF Measurements
- Other Measurements
Modeling
- Semiconductor Devices
- Passive Devices
- Behavioral Models
Design Languages
- Verilog-AMS
- VHDL-AMS
Simulators
- Circuit Simulators
- RF Simulators
- AMS Simulators
- Timing Simulators
- System Simulators
- Logic Simulators
Other CAD Tools
- Entry Tools
- Unmet Needs in Analog CAD
General
- Tech Talk
- News
- Comments and Suggestions
- Opportunities
« Home
‹ Board
» Powered by
YaBB 2.2.2
YaBB
Copyright 2002-2024
Designer’s Guide
All rights reserved.
Send comments or questions to
editor@designers-guide.org
. Consider
submitting
a paper or model.
