Aug 15th, 2024, 10:15am
Save waveform as a source in Spectre? (Read 3404 times)
littlepig
Mar 30th, 2009, 2:07am
Is a possible way to save output waveform and convert it to a source i.e. pwlf for Spectre??
Due to long simulation time for previous simulation, I would like to use the output waveform of the previous simulation and create as a source for subsequent simulation..
Thanks for the help..
Re: Save waveform as a source in Spectre?
Reply #1 - Mar 30th, 2009, 2:16am
littlepig wrote on Mar 30th, 2009, 2:07am:
Use ocnPrint() or table list ability in calculator.
Enter "ocnHelp 'ocnPrint" in CIW.
ocnPrint( [?output t_filename | p_port] [?precision x_precision]
[?numberNotation s_numberNotation] [?numSpaces x_numSpaces]
[?width x_width] [?from x_from] [?to x_to] [?step x_step] o_waveform1
[o_waveform2 ...] ) => t/nil
« Last Edit: Mar 30th, 2009, 5:30am by pancho_hideboo »
Reply #2 - Mar 30th, 2009, 8:47am
In addition, the results browser in IC613 also has a File->Export menu which can export "spectre" format - which is essentially a PWL input file.
littlepig
Reply #3 - Mar 31st, 2009, 10:23pm
Grin Grin
