idriss
Hi Andrew and Boe
first of all,thank you very much for your answers: actually Boe, I didn't make any typo errors in the model I didn't forget the _e.
I think Andrew is right something is going wrong during the compilation.
I am going to rexplain what I did: in the hierarchy editor for a library colp.... and cell HV45... I set the view to verilog reference which is a verilogams model idris which is in an other directory,until now nothing is wrong I am allowed to do that,this ams model contain and define a primitive called "u_lva2hvb_e". In the ADE when it compiles no issues,but when it elaborate I have this issue ncelab: *E,CUCFUN: instance 'lv_i' of the unit 'u_lva2hvb_e' is unresolved in 'C0LP_SC_18_LEVEL_LSHO25.HV45_O25_DLSUCIHLX4:module.
DO you see Boe what I mean, so what I did is in the directory where was the vams,I could see the 'u_lva2hvb_e' ,but couldn't open it,so I put in it the vams model of idris.so ok it could be open,but still the issue remains.
Andrew can you please show me an example of a script you use to solve this,because I tried to do like you said with the netlister but doesn't work. I will appreciate thank you very much, Idris
