Aug 17th, 2024, 11:19pm
low voltage, wide input CM samp (Read 88 times)
Jose
Apr 02nd, 2009, 1:06am
Is there any low voltage with wide input CM SAMP I can use? Currently, I'm using folded cascode topology for my design to archive wide input CM. Problem is it is not working well at low voltage.... Can someone please advice?
Thx & rgds,
Jose
raja.cedt
Re: low voltage, wide input CM samp
Reply #1 - Apr 2nd, 2009, 10:41am
hi,
   can you post your schematic?I guess rail to rail is  ok in this situation..but please send.
Rajasekhar.
