Jul 18th, 2024, 10:01pm
Jitter spec for OC192 (Read 3895 times)
casual
Ex Member
Apr 02nd, 2009, 2:25am
I am working on the CDR part of OC192 and I am new to it.
There are 3 types of OC192 jitter specification. They re jitter generation, jitter tolerance and jitter transfer. I am not very sure on the jitter spec. This is how I interpret:
Jitter generation: Clean signal is connected into CDR and measure the max pp clock and data jitter, am I correct? What is the max value for this? BER of 10^-12 must be achieved.
The most important spec is the jitter tolerance. The jitter tolerance mask must be complied. BER of 10^-12 must be achieved as well.
As for the jitter transfer, it is somewaht related to jitter tolerance. As long as jitter tolerance mask is complied. Then the jitter transfer will be ok with the condition of max 0.1db amplitude (jitter peaking requirement). Am I correct? How about the required bandwidth? Is the fc 120kHz only?
Hope someone can rectify my misinterpretation.
could you point me some good document about the oc192 jitter spec.
Thanks in advance.
  IP Logged
Visjnoe
Re: Jitter spec for OC192
Reply #1 - Apr 2nd, 2009, 2:58am
Dear casual,
the only way to go to translate these high-level specs into architectural/circuit level requirements is to have some form of system model where you can assess the impact of these parameters. If you're lucky, you can find some papers with closed formulae.
Peter
casual
Ex Member
Reply #2 - Apr 3rd, 2009, 1:53am
According to jitter transfer oc192, the cut-off frequency is 120kHz only. However the fc in most of the published journals is around mega hertz range, like 10-20Mhz, which is far exceed the requirement. Is it ok to do so? As I know those journals only focus on jitter tolerance than jitter transfer.
I really confuse  :o
  IP Logged
casual
Ex Member
Reply #3 - May 14th, 2009, 5:11am
Anyone know the reason?
  IP Logged
