Oct 5th, 2026, 7:29am
Reduction and (Read 4004 times)
neoflash
Mixed-Signal
Designer
Reduction and
Apr 02nd, 2009, 8:03am
what is the definition of "reduction and"  (&)  in verilog ams?
thanks.
Re: Reduction and
Reply #1 - Apr 3rd, 2009, 2:59am
It's a bitwise operator.  See section 4.2.9 of the Verilog-AMS LRM, version 2.3
Did you have a specific question about how it handles signed vs unsigned or unequal bit length arguments?
neoflash
Mixed-Signal
Designer
Re: Reduction and
Reply #2 - Apr 3rd, 2009, 5:07am
Thanks.
Just a little confused with what "reduction" refers to?
Re: Reduction and
Reply #3 - Apr 3rd, 2009, 8:42pm
Reduction & is applied to one argument and returns the logical and of all the bits in that argument. So it always returns a single boolean value.
This contrasts to the bitwise & that applies to two bit vectors, and return a bit vector where each bit is the logical and of the corresponding bits in the arguments.
So if A is 2'b11 and B is 2'b01, then &A is 1, &B is 0, and A&B is 2'b10. The first two are reduction &, the last is bitwise &.
Re: Reduction and
Reply #4 - Apr 6th, 2009, 4:33am
Oops, sorry, I was completely wrong.  I should have pointed you to
4.2.10 Reduction operators
The reduction operators can not be used inside the analog block and only have meaning when used in the digital context. Information on these operators can also be found in the IEEE std 1364-2005 Verilog HDL.
-- or you can just read Ken's post.
