Jul 22nd, 2024, 4:22pm
hspicerf simulation (Read 1482 times)
zhengzheng08
hspicerf simulation
Apr 13th, 2009, 1:18am
when i do a hspicerf simulation ,it reports errors as follows:
"~~resistor.lib incompleted input for .param statement"
whether it means that the lib losts something for rf simulation?
because when i use the same lib do hspice simulation for the same
design ,it runs without errors. who can  tell me what's wrong with
my simulation ,thankyou very much~~~~  :-[
spiceoracle
USA
Re: hspicerf simulation
Reply #1 - Apr 13th, 2009, 11:05am
In the resistor.lib file, look for any .param statements that have continued lines using the double backslash characters (\\).  If the .param statment has the parameter name separated from the first portion of the parameter definition, then this is the problem.  For example:
.param long_exp = \\
'((a+b)/(c*d) + \\
(v(out)*scale)'
The work around is to write the .param statment as:
.param long_exp = '((a+b)/(c*d) + \\
(v(out)*scale)'
This is a know problem and is fixed in the C-2009.03 version of HSPICE RF.
