Sep 19th, 2026, 12:27am
delay circuit (Read 7836 times)
Ajay
Asia
delay circuit
Apr 20th, 2009, 5:40am
I need a circuit for introducing delay . Delay needed is a few microseconds . Can someone guide me ?
thanks
buddypoor
Bremen, Germany
Re: delay circuit
Reply #1 - Apr 20th, 2009, 5:48am
Ajay wrote on Apr 20th, 2009, 5:40am:
thanks
For one frequency only ? Or for a certain band ?
Did you consider already an allpass circuit ? It´s easy to realize.
Have a look into a textbook on filter theory/circuits.
Ajay
Asia
Re: delay circuit
Reply #2 - Apr 21st, 2009, 1:18am
Its a digital signal that I need to delay.
When the input signal has a falling edge, the output of the delay circuit should go low after a few microseconds.
Can someone clarify how to implement this ?
Thanks.
Berti
Re: delay circuit
Reply #3 - Apr 21st, 2009, 2:13am
Do you have a clock available? Then you could implement a counter.
Cheers
aamar
Re: delay circuit
Reply #4 - Apr 21st, 2009, 6:53am
Two cascaded inverters will delay the signal without inverting it. If one of the inverters is larger than the other (alpha ratio>1) you can then control the delay.
Another possible way is to use a transmission gate as a resistance together with the input capacitance of the next gate will form an RC delay element
Best regards,
aamar
HdrChopper
Re: delay circuit
Reply #5 - Apr 21st, 2009, 8:46am
hi,
Apart from what aamar proposed, an additional option would be to have a couple of current-starved inverters. then the delay is controlled by such current and the input capacitance of the inverters.
Tosei
Keep it simple
AnalogDE
Re: delay circuit
Reply #6 - Apr 21st, 2009, 8:45pm
If you can build a current source, use it to generate a small current to discharge a large capacitor.  Precharge the cap to VDD and start discharging when the signal flips.  The delay can be trimmed by varying the discharge current, capacitor size and the trip point of the inverter that follows it.
Peruzzi
Re: delay circuit
Reply #7 - Apr 22nd, 2009, 6:45am
Ajay,
All the responses are viable choices, but a couple of very important criteria were left out of the original question: How precise does the delay have to be, and does it need to be consistent over processing, power supply voltage and temperature?  Your answer to this determines which of the proposed solutions you choose.
Best regards,
Bob P.
www.RPeruzzi.com
Ajay
Asia
Re: delay circuit
Reply #8 - Apr 25th, 2009, 6:02am
Hello Peruzzi,
The delay circuit must give a delay of nearly 3us for all process corners and temperature variation from -40 to +125 degreeC. Supply voltage can vary from 1.8V to 3.6V.
Which solution is the suitable one ??
Thanks and regards.
Peruzzi
Re: delay circuit
Reply #9 - Apr 25th, 2009, 9:00am
Ajay,
Berti's solution wins, because of your requirement for consistant delay over PVT.  Use digital delay -- a divided down clock and a counter.
Any other opinions?
Best regards,
Bob P.
www.RPeruzzi.com
cmos.analogvala
India
Re: delay circuit
Reply #10 - Apr 25th, 2009, 9:12am
This Clock + counter is a useful only if clock frequency doesn't vary with PVT.  If I am not wrong,  clock frequency varies with PVT.
CA
Peruzzi
Re: delay circuit
Reply #11 - Apr 25th, 2009, 9:23am
CA,
I suppose everything varies with PVT to some extent. Wink
Ajay hasn't posted all the constraints, but with a crystal oscillator and PLL, clock variance across PVT can be made negligible.
Bob P.
www.RPeruzzi.com
