Jul 18th, 2024, 7:26am
How to turn off model related warning in hspice simulator? (Read 3085 times)
neoflash
Mixed-Signal
Designer
Apr 21st, 2009, 3:06pm
For example, some models are not used and there is going to be many warnings, which make the real important info hard to find.
 **warning** (/tt_lk.l:10414)   model nch_lvt.1 is not used in netlist
nobody
Re: How to turn off model related warning in hspice simulator?
Reply #1 - Apr 21st, 2009, 7:03pm
I think you can try to turn off that model in the model card directly.
Reply #2 - Apr 28th, 2009, 5:18am
Check your .option statement; I wonder if you're somehow requesting those warnings, I don't think I usually get them.
Also consider NOMOD or BRIEF
spiceoracle
USA
Reply #3 - May 7th, 2009, 3:17pm
By default, HSPICE only loads the models that are actually used by the circuit.  This has been the default behavior since the A-2008.03 release.  Doing this saves memory and run time since every model and model bin is not loaded and evaluated during the read in phase.
Using .option brief=1 and brief=0 around any .lib statements will prevent HSPICE from reporting which models are not used.
