spiceoracle
USA
You can use
.option POSTTOP
to output only the node voltages and source currents at the top level of the circuit hierarchy.
You can use:
.option POSTLVL=n
If you want to output only the node voltages and source currents at a specific level of hierarchy specified by n.
One caution, the POSTTOP and POSTLVL options will be ignored if
.option PROBE
is also in the netlist.
